My intent here is to bypass the heat exchanger until the engine reaches operating temperature.
all it will take is one time forgetting to open the bypass valve will show you how bad and expensive of an idea that is....
beside, you already have an
automatic valve that does this called a thermostat.
its NOT the heat exchanger that causes the speed at which the engine heats up. its the thermostat within the engines cooling loop that does this.... as long as there is water in the block, nothing else in the system matters until this water comes up to temp and the thermostat opens... if the thermostat FAILS to close, the water will freely circulate thru the block and will take much longer to heat up. if its closed, the water will remain stationary against the heat producing parts of the block and will be heated as quickly as the heat is generated.... it does NOT even reach the heat exchanger UNTIL it becomes too hot for it to be effective in cooling the hot engine down....
Dont ever restrict the heat exchanger...
