Rick J
Hello all. Regarding the 'false bilge' (or whatever it's called, since the H31 seems to have multiple false bilges, among other strange things) that is located just forward of the engine, beneath the companionway ladder, I have a dumb question: is this area supposed to drain to anywhere in particular? Mine doesn't. If not, what is the source of water that seems to accumulate there? Mine has a hole leading to somewhere toward the aft portion of the compartment; just aft of the aft keel bolt, if that makes any sense. I have no idea where the hole is supposed to go, of if the compartment fills through that hole, or if it's supposed to drain through the hole.And, moreover, I wonder what would happen if I just plugged the aforementioned hole? Would that prevent the accumulation of water in this compartment? It's a bit of a pain, insofar as I have to suck the water out of this area from time to time, and by that point it has become stagnant and funky. Plus, the aft keel bolts are continually bathed in the water sloshing around in there.My boat is an '87. I've had this boat for several years, and I've always been too embarrassed to ask about this issue, thinking that it would become, as they say, intuitively obvious to the casual observer. But I'm tired of having to suck out the funky, stagnant friggin' water from down there, so I'll just have to finally ask what is probably a truly stupid question.Thanks - Rick
