Factory over spray on windows
StevenH
When cleaning on my new Hunter I noticed a white overspray on almost all of my windows. I tried window cleaner but had no luck. Any ideas on how I can safely clean this stuff off with out damaging or scratching the windows.
Robert Polk
Don't use Ammonia based window cleaners
Don't use Ammonia based window cleaners like Windex - They will make your lexan windows get hazy and cause surface cracking.. Use a plastic cleaner polish avaialble from various manufacturers and available from Boat US, West Marine etc.
Jim WIllis
Try Island Girl Pink
If overspary is regular (singel part) paint yo will be able to reove it by carefully rubbing with some paper towel dabbed in a little IG pink. If it is two part LPU or gelcoat, there is no solvent you can use that will not also damage plastic windows (glass would be a different matter there you could use acetone). All you cna do then is to use some very fine metal polish or following with our CLLAR HORIZONS. You could use Meguir's platic polish also for this but there is much less abrasive content and may take longer. This also ahs a resin shine enhancer. Thanks Jim Willis ISLAND GIRL PRODUCTS
