Dan, did you get your 235 from....
Just wondering where you got your F235? I saw there was one for a very cheap price near Washington, NC and also one in Charlotte on Lake Norman. Wondering if you got either one of them. The Little Washington boat was dirt cheap but looked lived in a bit. It was around the same price I got mine. Btw, my keel is finally done and it turned out pretty well. I ended up going with a grinder to bare metal and the two coats of POR-15, followed by West Systems Epoxy with Low Density filler (#407) for fairing. I had bought a quart of the Interlux 2000/2001E Epoxy paint but instead just put on two more coats of POR-15 since I had PLENTY left from the quart. The POR-15 dries ultra slick and hard. It's a shame to cover with bottom paint.Getting ready to replace a thru-hull and ball valve and tackle the nasty vinyl job... Still might be going without the topsides vinyl stripes as I removed it and dont mind the clean look for now. Gaskets havent been done but I now think I am getting the slight leaking from the port jib track. I have to get the hose out.All of this mess will end up in the F235 site with more pics. Although, I am going to Siena, Italy for three weeks on the 15th so that throws a severe left hook....As for the towing, I towed my F235 from Charleston, SC 3.5 hours and it was an easy pull, this not even with a trailer made for it.Keep in touch on your repairs.Kellywww.beneteau235.com
