N
Neil
My (new) F235 (wing keel version) is moored in a berth that is exposed to lots of boat wake. To minimize the boat's to-ing and fro-ing in the berth, I decided to back it into the space so the bow and not the stern meets the incoming wake while it's moored. The problem is that the inner end of the slip is rather shallow - in fact, when bigger-than-average wake rolls in, the rudder touches the bottom pretty hard! I really would rather not turn the boat around so I'm wondering if I can conveniently leave the rudder raised a but while the boat's moored.The lower nylon rudder bolt is too hard to reach from the cockpit or even the dock so I wonder if I can just leave that one loose all the time (so it won't impeed raising the rudder in the berth) and try to hold the rudder up just with the upper bolt. However, these bolts are VERY stiff (any tricks to make them turm more easily?) so I'm concerned that frequent adjustment may break them off (I've already had to buy a new pair because the bolts that came with the boat were split). How much will a loose lower bolt affect the boat's sailing performance? Is there a better way to securely hold the rudder about a foot while it's in the berth? I think if I can raise it to the point where the tiller pushes against the stern lifeline, it will be high enough and I won't have to unship the tiller.Any advice will be much appreciated.Neil
