I have a 34 foot Hunter and want to install a xxjack system to hold the sails once they are dropped. I've seen a variety of systems and even have someone who will install his own version. What should i be looking for in a xxjack system?
When you get one:
Lazy Jack Trick
Many folks complain about full battens getting caught up when raising the mainsail. They then spend a lot of time moving BOTH sides of the lazy jacks to the mast.
We developed an easier way with our lazy jacks.
We have a small cleat on the forward starboard side of the boom. When we put the halyard on the headboard, we move ONLY the starboard side of the lazy jacks forward and snug them under the forward side of the horn of this cleat.
Then, when we raise the mainsail, instead of going exactly head to wind, we bear off a tad to starboard so the wind is coming from the port side of the bow.
We then raise the mainsail and it doesn't get hooked on the lazy jacks even though the port side jacks are still there.
Been working for 16 years.
Yes, we have to go forward again to unhook the starboard lazy jack for dousing the sail if I forget to do it right when the main is raised, but there's never any hurry. The drill is: after the main is raised, I unhook that starboard lazy jack, so they're both ready to go when we drop the sails at the end of the day.
So, for those of you with lazy jacks, consider doing only one side.
Your boat, your choice.
Excellent idea!
Chris
C:\Users\Stu\Stu\Boat\Lazy Jack Trick.doc
Skipper your system is similar to what is called Lazy mate. It is on my list of things to do. It looks like simple enough system. I thought that I would just do the bottom 2/3rd's of the sail.I merely tied appropriate lengths of cord to the reef points on the leech, and shackled the ends to the topping lift where they slide up and down. Works great for keeping much of the sail on or near the boom, and I can flake the sail and tie it up easily without leaving the boom. And still can use the reef points if needed. Total cost: $0 -I had the small shackles in inventory.
Yep, my old boat had the lazy mate. That's where I got the idea, when I discovered this one had no system.Skipper your system is similar to what is called Lazy mate. It is on my list of things to do. It looks like simple enough system. I thought that I would just do the bottom 2/3rd's of the sail.
http://westsail.info/index.php?action=posts&thread_id=1491
