ez jaxs
L
Larry Jordan
Hello everyone, Let me thank you in advance for any help or advice you can give me. I am looking to put a sail handling system on the main. I was looking at the e z jax system and was wondering if anyone has any feed back or a system like it? I just put on a Kiwi Feathering prop so in time I will be able to give feed back on that with in a few weeks. Thanks again. Larry Jordan S/V Valor, C&C 35 mk III Kent Island. Md
RichH
Feb 14, 2005
4,773
EZJacks.... Love 'em!
Ive been using ezjax with 'wonderful' results. The chief benefit is that they can be completely retracted and 'out-of-the-way' when not needed. I use them on a 440 ft. sq. main made of stiff 9.5oz. material ... and can almost forget about 'tying-in' the first two reefs. A necessary addition is small bungee cords attached to the cap shrouds to keep the small (bullet) blocks away from the mast (chafe) when the jax are 'stored'. I prefer not to use a toping lift; instead use a rigid vang ... so that disqualifies a 'dutchman' system.
Feb 21, 2004
3
Hunter 40 St. Pete Beach FL
E-Z JAX are Great!
E-Z JAX are not the only answer to the problem of flaking and controlling the Main. However, that's the way I went. Very economical!
C
Charles
Installed Mine Last Week
Completed installing mine on a 37 cutter last week and they work great. Makes sail handling much easier and are out of the way until you need them.
