Hi all. While I was in Santa Catalina Island, a guy next to me fouled his prop on the mooring line and swung into me. His pulpit kept the hull off but one of my stanchions was bent. The stanchion is attached to the hull by a through bolt on the rail and has two inboard leg supports that tap into an aluminum plate in the deck lay up. At least it was a Swan that did the damage
So, I figured I would have a problem with the 1/4 inch Phillips head stainless screws into the aluminum plate after 24 years. I took my impact wrench to work them. The first one came out fine; the second one stripped the head due to a poor angle (I think). I tried creating a slot, but that didn't work either. So, I drilled off the head.
Any suggestions on removing the shaft of the 1/4 inch screw? I have used easy-outs before but never on something this small. Suggestions welcome! Taking the stanchion to a local body shop to straighten.
(Yea, I know the guys owes me a fix, but this stuff happens and I don't feel good about having a yard do something "this simple".)
