Mark
Down here the shortest shaft outboard is 15 inches.One of the smaller yachts I own (18') has always had an outboard hanging off the back. It needs replacing however what I would like to do is mount a new motor in a "large" stern storage box on the yacht. The idea is that either side of the leg, a section is cut out of the hull in the stern box for the leg to extend into the water so that it just protrudes from the bottom of the hull. Enough for the cavitation plate and so water inlet to be submerged of course. On each side of the hole there needs to be a glassed in wall from the hull verticle to be made well above water line. So I guess I will end up with an "inboard-outboard".My problem is trying to locate a motor with a shaft length much less than 15 inches."Help" Any ideas??
