External fuel tank for 5 hp o/b
E
Ernie Rogers
I have a 5 hp Nissan o/b on my '86 h23 which has about a half gallon tank. I'm looking for advise on adding an external 6 gallon tank. Is there more I should know beyond cutting in a tee to the fuel line and adding the male/female connectors? Or would it be best to completely disconnect the internal tank? Thank you for your input. Ernie Rogers h23 "Whimsy II"
Bill Murray
fuel pump
I know zip about this particular engine, but check to see if you have a fuel pump or if it is a gravity feed. Even with a fuel pump, check to see what the specs are for lift; i.e. will it have enough oomph to pull the fuel up from the tank location you are considering. Bill Murray S/V Good Faith H29.5 #175
Pete
fuel tanks for outboard
Ernie, I would think you will need to do more then cut a tee into the fuel line,at least you will need to add a value to shut off the internal tank or what will keep it from going empty and sucking air instead of gas and acting like it is out of fuel. I think the answer here is with the mfg to see what they recomend! Another thought comes to mind is to just eliminate the internal tank and use the big tank only! Bill has a good idea about checking to see if the fuel pump is even capable of being used with a external tank, again something the mfg or local dealer should know! Good Luck!
Jon Bastien
Nissan 5 HP motor should be OK...
...with the external tank. I've seen this modification made a few times to that particular motor (NS5B, I think is the model?). Personally, I prefer the external tank anyway- Less likely to run out of fuel when I need it most. I don't remember anyone mentioning a need to beef up the fuel pump. Of course, on the H23, the fuel 'locker' is higher than the outboard motor mount anyway- This creates a siphon, which takes away most of the need for a stronger fuel pump. I'd recommend turning off the master fuel valve when the motor is not in use, to prevent flooding its carburetor. The post about either removing the internal tank, or installing a valve between the internal tank and the tee connector is spot-on. I've seen both, but I think the preferred method is to remove the internal tank. There are some advantages to the 2-tank setup, as well- If you ever have to drain the internal tank (a good idea for transporting), all you have to do is put the external tank lower than the internal tank and open the valves and vents- Gravity takes over. The same is true in reverse, so you MUST remember to close that valve when you use the external tank as the motor's fuel source! Finally, I'd recommend going with the Nissan-style fuel line connectors, for two reasons. If you look at the front of the motor, there's a rubber plug next to the 'kill' button- The fuel fitting should fit there nicely, as that's where Nissan puts them when they build the motor for use with an external tank. The other reason I recommend them is because the 'OMC' type connectors SUCK- Always leaking, and sometimes falling off(!!) when you need them most. Good luck! If you're not too mechanically inclined, a good small-engine mechanic or outboard repair person ought to be able to make this modification pretty cheap- perhaps even as cheap as a 12-pack of their favorite beverage and parts at cost. As always, if you have any questions, just holler... --Jon Bastien H25 'Adagio'
E
Ernie Rogers
Thanks for the info!
Yes, it's a NS5B. There's also a model NS5BS which comes with an external tank. I'm going to try it first without any other modification. If it doesn't work, I'll add on a supplemental electric fuel pump I guess. Thanks again. Ernie Rogers h23 Whimsy II
