exterior refinishing
Nov 8, 2001
1,818
abye not have to do anything for five years but sounds an awful lot of work
for just the woodwork. I would just clean each season and oil with a marine
wood oil. Easy to do and satisfying.
Regards
Steve Birch
At 13:20 21/05/02 -0800, you wrote:
Oct 30, 2019
77
refinishing the outside as described by a professional wooden boat builder of considerable reputation will entail sanding and the coating with epoxy and resin(3 coats)and then you won't have to continually varnish or oil for approximately 5 years.
Dave
v3233
Nov 8, 2001
1,818
I agree or just use a good oil and just keep adding coats every now and
then... looks good, tastes good and by golly does you good...
Steve B
At 11:53 24/05/02 -0700, you wrote:
mocap1
Oct 31, 2019
96
Unless they are now making UV resistant epoxies, you will still have to use
a varnish with UV inhibitors on top of the epoxy. I have extensive
experience with epoxy resin, although it is not current, and I would use
only varnish, and forget the epoxy.
Mort
