Some Good Leads.....
In addition to any replies that you might get here, in the section of this web site under "The Boats", "350", is some useful areas. One section has a review by an owner and another section has four owners listed and, as a suggestion, you can write E-mails to them. My experience has been, of the E-mails you send out, expect about a 50 percent reply rate.For a coastal cruiser or family boat, the 35 footer is a good size and a very cost-effective boat. Depending on how much stuff one takes along (we take a lot), for longer trips it's more of a couple boat due to stowage limitations; however, in the Northwest one has to be prepared for hot and cold, rain and non-rain, and occassionally sun. Each weather condition requires different clothing which must be packed and which requires stowage space, and longer trips requires changes of clothing.Good luck in your quest for information and hope you get some responses. Because different models often use the same or similar equipment, information about related models could prove useful, i.e., same model year but different size or same size but different model year.
