PAUL
I was told to replace my exhausthose from the mufler to the thru hull fitting. As i removed the orginal, old cracked hose, i noticed that 90 bend to the thru hull fitting compressed the steel lined 2" hose and restricted the flow of water, there was also another large U bend. I than tried to install a new hose bought at the marina,along with new SS hose clamps. This is when I decided that this orginal installation must be wrong, Has anyone run into this problem.
