Derek Rowell
I'm in the process of purchasing a boat with a 55hp Yanmar that has apparently had very light use and low hours (according to the broker - no hour meter - he estimates 450 hours on a 1985 engine). Sea trials are not practicable, so the broker had the engine started on land with a recirculating coolant system. The boat had been sitting all winter. The engine started right up and ran very smoothly - but with a LOT of smoke (I couldn't decide if it was black, blue or white - I would say dirty whitish blue
. The amount of smoke diminished a bit over the 20 minutes of the test but it was still significant at the end. The engine was at idle with no load for the duration of the test. The cooling system was working fine. I could see no trace of fuel in the circulating coolant. The broker and mechanic (and my surveyor) were not concerned. The mechanic said it was because the engine was not up to temperature at idle, and that as soon as some load was put on the engine the problem would disappear. But he works for the broker... I have been around sailboats for a long time. I have never seen so much smoke from a sailboat diesel. My current Yanmar (22hp) will only show exhaust smoke for about 30 seconds at idle on start-up each spring. Is twenty minutes of smoke too long? I am concerned that this indicates a severe compression problem. Derek
