Exhaust riser
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
Any new products out there for covering exhaust riser? paulj
May 6, 2004
916
Hunter 37C Seattle
Paul, mine is just warm to the touch
immediatly downstream from the raw water discharge of nice cold puget sound water. I don't have/need any insulation on it.
Dave
Exhaust
I am in the process of replacing mine and am going to use "header tape". It's what the hot rods use on the tubes of their exhaust to keep the heat down under the hood. Hot rod shop or on line has it in different sizes. Dave
Dec 2, 2003
210
Hunter 34 Forked River, NJ
If the riser is hot to the touch,
you probably have to replace it, as the reason for the riser in the first place is to cool the exhaust with water. Your pump, hose, and fitting for the water injection into the riser may be fouled. It should only be warm, not hot.
