exhaust riser
macwho
Jul 24, 2015
21
Catalina 30 TRBSWK Sandusky BPM
Has anybody upgraded to the cast riser Westerbeke # 200490. What do you run from riser to water lift muffler. How does it attach to engine. Any Info would be appreciated. Thanks
jviss
Feb 5, 2004
7,089
Tartan 3800 20 Westport, MA
It looks like the one on my engine, I think Westerbeke uses this in a lot of applications. There is a mating flange on the exhaust manifold and a band clamp with a groove inside that squishes a gasket between the two. Mine was installed with "standard" marine reinforced exhaust hose.
You should check the documentation on the Westerbeke site, they have a really good library for most engines they have sold.
macwho
Jul 24, 2015
21
I checked Westerbeke's site but they must not have used this riser with a M25XPC engine. I also changed To a Oberdorfer raw water pump (N202M-16) and I had to do the Mod the same as the M35. Thanks, you did answer a lot of my questions. I will need to see if I can change my exhaust flange (#298599) to one like yours. I may need to call them.
