Exhaust Riser - Repair or Replace
Ward H
Nov 7, 2011
3,798
I've read threads on the Yanmar exhaust riser getting clogged and developing pinholes. Those wet risers are a bit different from the Universal M25XP exhaust risers which are mostly dry risers until the last few inches where the water is injected in the riser.
Here's a photo of the stainless steel exhaust riser I just removed on my M25XP. I was raising the engine to pull the tranny when the water injection nipple got caught on the side of the structure. After getting it cleared I found the nipple was loose and the weld fillet on one side popped right off, like it was slag.
I was thinking it was a bad weld and I could have it re-welded but maybe it is normal corrosion for that area? The rest of riser looks good except for maybe the pipe nipple going into the exhaust flange. That doesn't look like SS and is a bit rusted.
Age of the riser is unknown.
Thoughts on repairing? Can SS develop pinholes like the cast ones on Yanmar so I should replace it while I have it apart?
New SS riser and flange from Catalina Direct is a bit pricey at $600. Looking but have not found another supplier.
Jun 11, 2004
1,816
Oday 31 Redondo Beach
$600 is a lot of dough. I think a lot of people fabricate their own risers with black iron pipe from a hardware store. I did for my Universal M18 and it has worked well.
Looks like you might want to buy a new flange though.
Here's how one guy did it.
I didn't buy the welded nipple but cobbled one together with tees and wyes.
Tom J
Sep 30, 2008
2,325
Catalina 310 Quincy, MA
I would definitely replace that. Whether you go new or fabricate depends on your budget and/or your time. If your budget won't tolerate new, spending the time to fabricate could well be worth it. Others on this forum have fabricated exhaust elbows, mostly from SS. If you have access to a welder, I have found that ss welding rods actually flow very nicely.
Likes: Ward H
May 29, 2018
619
Canel 25 foot Shiogama, japan
Everything is repairable.!!!
An exhaust riser is not a complex piece of machinery.
The flange is reusable. (Cut off, rebore and rethread)
Maybe even the riser pipe itself.
It is joke (or a crime) to charge $600 for something like that.
Send it to Kurtis. (Just kidding)
Likes: Ward H
May 25, 2004
443
Catalina 400 mkII Harbor
heres a copy of my post from a few years back, you wont be disappointed!
Got to give a shout out to HDI Marine, especially Hailey!
thursday before labor day i was fueling the boat for a lake michigan crossing the next day friday, i noticed that the mixing elbow was leaking. i had remembered that HDI offered a stainless steel replacement for the yanmar. Hailey call me back quickly and asked if i took it apart yet. which i hadnt, she recommended that i also ordered the 90 degree piece that went to the engine. she stated most get broken in disassembly. i ordered both pieces overnight. received friday morning, installed in under 2 hours and week end went on as planned. oh, with overnight shipping ($70) the total was only around $300. sweet deal!
thanks Hailey!
thanks Hailey!
My first thought was to replace it.
The second was WTF? $600 to replace it?
The third was Contact HDI Marine.
DArcy
Feb 11, 2017
1,773
Islander Freeport 36 Ottawa
Look around to see if you can find a stainless exhaust, but it will likely be specific to your boat model so may be limited to Catalina direct. The exhaust on my old C&C27 was getting questionable. It was black iron pipe and lasted about 40 years (fresh water boat) so that's what I used for the replacement. The original had the water nipple welded in but I don't have a welder so I threaded the nipple in. I used high temperature pipe sealant all around. Flanges for the Atomic 4 were still readily available and the rest was from a plumbing store.
Jul 8, 2012
138
Catalina 36 MKII North East
When my exhaust riser finally crumbled I made a new one out of schedule 40 stainless pipe nipples purchased online. Luckily a friend drilled and welded the water inlet into one of the 4 inch sections, the option would have been to take that bit to a local fabricator or exhaust shop. This photo is while measuring and fitting, before the inlet installation above the silicone hose. All threads were sealed with exhaust goop and ultimately all covered with exhaust header wrap. Total cost for the stainless was under $100, I also paid for a new exhaust flange and gasket from Universal to make the job easier -
Ward, since ya already got it out, replace it. Good ideas here as to options of how to do it. CD sells the ss but require you to buy the insulation too, or they won't sell you the metal! It's expensive, but a good package if you don't build one yourself. Tapping in a nipple seems superior to me than the welded nipples, which are also available online as a union or piece of pipe. I've replaced my riser two or three times over the last 25 years. Make sure you (re)fit the pipe into the back of the flange with a vice; hand tight is NOT enough.
For those with Yanmars, the Universal risers are COMPLETELY different than yours. They perform the same function of mixing the water with the exhaust, but, as you see, in a completely different configuration.
Oct 26, 2008
6,320
Catalina 320 Barnegat, NJ
Yes, replace, I think. The failure at the nipple looks pretty bad. Good thing you have some time. Exploring a less expensive option may be worthwhile. Your fall-back can be the CD option if they are reliable about a delivery date.
Likes: Ward H
Ward H
Nov 7, 2011
3,798
Replace it I will.
My research shows one of the larger Catalinas came with a SS riser so I'll call Catalina Yachts next week. To be honest I'm not sure if this one came from CY or CD. That cost from CD is total for the flange, gasket, hump hose and riser. It was $472 just for the riser itself but I need all three.
I'll also call HDI Marine but their website only talks about cast pieces.
I'm considering making my own out of SS. I've seen recommendations to use Schedule 80 pipe and fittings but I need to find a source. @brazenarticle Where did you source your parts?
Tom J
Sep 30, 2008
2,325
I wouldn't dismiss the idea of cast pieces entirely. If you follow best practices for diesel operation, you can get many years out of a cast system. Always warm the engine up before putting it in gear, run it hard and don't idle it too much. My 2003 cast elbow has 1600 hours on it and is in very good condition.
Likes: Ward H
Jul 8, 2012
138
..I'm considering making my own out of SS. I've seen recommendations to use Schedule 80 pipe and fittings but I need to find a source. @brazenarticle Where did you source your parts?
I used 1 1/4 inch schedule 40 fittings purchased online from ZORO.com. The material is much thicker than the original riser and should last many more years. Schedule 80 seems like overkill.
If you have the room a pair of 45 degree elbows instead of one of the 90s may make fitting everything easier. I unscrewed the water muffler from the hull, moved it half an inch and reattached rather than continue messing with fitting the riser. Good to have that bit of wiggle room - the muffler is just 4 screws into plywood glassed to the hull on my boat.
Another lesson learned, don't dry fit the stainless. The threads gall easily and can be a bear to get it apart. Measure many times and assemble it all once if possible.
  • Helpful
Likes: Ward H
A high temperature pipe dope should prevent galling. Galling is caused by the heat developed by friction, sometimes called cold welding.
Likes: Ward H
DArcy
Feb 11, 2017
1,773
Galling is not really caused by heat but pressure combined with movement causing shear stress at the material surface. Galling is micro displacement on the material surfaces that look like fish scales. The "scales" are opposing so lock the threads in place.
Galling generally occurs when a load is applied to the fasteners during assembly, while the threads are sliding over one another. This is why locking fasteners are more susceptible than free running. Pipe threads are tapered so as soon as you start to feel resistance there will be pressure exerted on the threads. Lubricants greatly reduce galling because they reduce the shear forces on the mating surfaces. Pipe dope would probably act like a lubricant.
Stainless steels are more susceptible to galling than other materials typically used for threaded interfaces, although using two different types of stainless with different hardnesses also reduces galling. Unfortunately, you are going to be limited in material selection for pipe fittings. If the manufacturers of the fittings understood galling they would likely take this into consideration and make the pipes and the fittings from different hardness stainless.
Ward H
Nov 7, 2011
3,798
I'm not dismissing HDI because they do cast pieces. I've found threads and articles where the Yanmar type cast wet risers are installed on M25-XP engines and even on C30s. That install requires major modifications to the exhaust system including a new dry lift muffler.
I just don't see on the web site where they do custom stainless pipe risers like I need.
Good info. Thanks
Ward H
Nov 7, 2011
3,798
Just a quick update.
Called HDI. They said they might have a solution, send them a photo. I did and waiting for a reply.
Called Catalina Yachts. They did supply SS exhaust risers in the C30s starting in the early 90s so mine might be original. They no longer carry them and directed me to Catalina Direct. While the CD riser matches the dimensions of mine it is not an exact duplicate. Maybe mine is 29 years old.
Putting together a parts list to see what I need if I decide to build my own.
Likes: Tom J
