Dimitrios Degiannis
My Oceanis 393 (Yanmar 4JH3E 56 HP) suffers from excessive engine vibration when revs go up between 1000-1700 rpm, whereas I do not experience any vibration when I reverse or when the boat has acquired speed, I put the lever in neutral and I increase then the revs.I have changed the engine mounts with brand new original ones from Yanmar, I believe that the engine-shaft are perfectly aligned, I have changed the cutlass bearing which was completely worn out and I took the propeller to a local specialist, who (without sophisticated equipment) told me that he cannot see aything wrong.Despite all these, the vibration is still there and I am desperately looking for suggestions! I must point out that I bought the boat secondhand 12 monthsw ago, it had the problem from the very beginning and very stupidly, after testing the boat with my mechanic, I accepted his view that this must be a simple misallignment proplem which can be fixed.Questions:1. Can a balanced and not bent propeller cause such a vibration in a yacht like this?2. Does it make sense to take out the propeller and run the engine in gear to see whether the shaft vibrates without the propeller?
