Having removed the swim ladder on my 192 to better polish the transom, I am now replacing 3 individual wood reinforcement blocks with a single sheet of 1/2" fir external ply.
Do you all think I should coat the ply with epoxy? Fir will still check with an epoxy coating. Also, if I bed the fasteners properly, there ought to be no water touching the ply.
Should I epoxy glass fabric on one or both sides? Theoretically, a solid sheet of ply will be stronger and less likely to allow the ladder to torque, so the additional strength of glass layers shouldn't be necessary.
Should I epoxy the ply to the inside of the transom? Again, I'm thinking a solid sheet of ply should provide more support than the individual blocks, so again this should be unnecessary.
Thanks for your opinions helping talk me into or out of more work!
Brian
Brian
