E
Ed Ryan
Have to replace the last of the sanitation hose and the runs seem to be exceedingly long. The ones in question go from the head on the port side, to the area under the bench seat in the main saloon (so that the hose can turn), underneath the sole to a vented loop in a drawer stack on the starboard side of the v berth. The hose length of that run is about 13 feet. From the other side of the vented loop, it goes down under the v berth to a Y valve (a run of another 4 feet) and then on to the holding tank (another 3 feet). (The other side of the Y valve goes to a through hull for pumping overboard, which is never used although it may be at some point. In addition, I have the capability of pumping the holding tank overboard with a Whale pump, although that is not used currently either.)Based on what I've read, the total distance from the head to the holding tank should be around 6-8 feet. Any ideas to change the configuration and/or shorten the main run from the head to the holding tank? With a total distance of 20 feet, it would take a lot of pumping to clear the line.Peggy - I have a Raritan PHII. Assuming that I have to maintain the status quo of about 20 feet, how many pumps does it take to move whatever is in the bowl to the holding tank? Also, would it make sense to add the KO through the pump out fitting instead of flushing it through the head?
