Bob
We have a 1976 Hunter 30, which will we are going to start putting back together pretty soon (weather permitting), The whole electrical system is going to be replaced, and I have been (kind of) plodding through the way the old one was put in. It seems like most of the gound(s) ultimately wind up at the motor. The questions I still have is 1) is there some internal (in hull) ground from the keel to the motor (or should there be), 2)is there some internal ground from the mast to the motor (or should there be). I am not sure if there are any zinc's on the hull, I just havent looked, and I am not sure if there is supposed to be. I know there are two on the shaft, and the new motor has zinc's. Do I need to put additonal one anywhere else?. I haven't gone so far as to use a multi-meter yet. I have a new Blue Sea Systems 8084 (Ac-DC) panel, and all of the circuits (Both AC & DC) have positive lugs,negative lugs, and common ground (via a bus bar). The DC grounds are all interconnected, the AC grounds all go to the shore power ground (through a BUS bar). Any help (in laymans terms) would be greatly appreciated. I am not going to use any bus bars, I intend to run all new wire from the panel to each and every appliance, outlet, or demand, no breaks, no splices. I personally dont have much faith in crimping connections, so I intend to solder all the connections to lugs, terminals or connectors, and heat shrink them with adhesive heat shrink. Any insight or experience would be greatly apreciated.
