The Everware laminate in the cockpit of my Hunter 38 is stained. I have tried soap and water, but to no avail. Does anyone know of a safe way to clean the stuff. Darn seagulls.
I know it sounds funny but you might try white sidewall tire cleaner. Ive used it on the rub rail of my boat and scuff marks on the hull with good results. On the rub rail I do a few feet using a scrubble and rinse with fresh water. It might be worth a try on your laminate. Do a small piece first to see if its compatible with the laminate.
