I installed a new Rule float switch in January. Worked fine, then failed yesterday. I drained the icebox into the bilge, and the pump didn't come on. Tested, bypassed, fiddled with the float, etc. Pump worked on manual, and when jumping the float switch. At one point I got the switch to work, but with obviously reduced current to the pump. Then it failed altogether again.
So Rule is sending me a replacement. But I started wondering, what if I just wanted to fix the one I've got. What if I had to do it 'cause I'm somewhere with no access to new switches?
There is no obvious flaw on the switch externally. I'm thinking about busting the failed one apart(Rule didn't want it back). But, if someone knows what to look for, and who has taken one apart, maybe some up-front knowledge can be had, and I can save the old switch for when the new one fails.
