Even a daysailer deserves a bit of bling
259
Hunter 15 Fremantle, Western Australia
Having a lot of non sailing time on my hands after ripping the inside of my knee and then fracturing a bone in the same leg, I turned my mind toward messing about with my boat. Enthused by the great mod that Rusty S of the Hunter 170 owners did to his tiller (see Hunter 170 Owner Modifications), I put my mind to my own version.
The attached photos tell the story. The SBO Store supplied me with a tiller for a Hunter 23.5. This most closely matched the length and shape of the original steel Hunter 15 tiller. Cheek blocks, rudder head replacement are aluminium.
A solid aluminium bar replaced the original spacer that was at the top of the rudder assembly (this spacer used to hold the butt end of the original tiller). A 2” aluminium strap was screwed to the top of the bar. Cheek plates that were mounted on either side of the wooden tiller’s 2 inch sq butt end extended down either side of the strap to provide lateral support and also extended a bit further at the rear to provide for a pivot pin to go through the cheek plates and solid bar. A custom pivot pin for the tiller was turned out of stainless steel. I also glued a strap of Teflon to the underside of the tiller where the wood meets the metal strap to protect the varnish.
On the front of the solid bar I added a quick release clamcleat (CL257) to hold the rudder down but release it quickly if an obstruction is hit as well as keeping the original CL 218Mk2 (to hold the rudder up). The rudder control lines were fed through deck eyes that were mounted in spare holes in the original rudder cheeks and then through some small cheek blocks mounted on the solid bar to provide a little mechanical purchase.
I upgraded the existing tiller extension with a Spinlock EA 1200 (750 -1200mm) Asymmetric Handle Tiller Extension.
The design and manufacture process was a lot of fun for me and an old work colleague, but as I sit here, looking at the photos that I posted, I find myself saying, if I were to do it again I'd change......
Now, if I can only find a nice flag pole for the holder I added.
Here is the original:
This is my interpretation of what a tiller should look like:
Feb 26, 2010
259
Hey Chris,
Thanks for the compliment and the good wishes. I hope to be back in my boat by late January. This project was a first time effort for me. If I had to do it again I would do it differently. Ah, live and learn!
Cheers,
Hollis
