I have recently purchased a 2003 Hunter 386 in Vancouver Canada. The Espar heating system was working when I got the boat but now it does not come on at all. I suppose this is a dealer installed option rather than a factory installation. There are 3 hi/low fan switches and 1 thermostat. The procedure is to turn on the fan switch for the zone you want to heat and then set the thermostat. None of the fan switches turn on the fan. The fuse in the thermostat tests good. The fuse in line with the battery tests good. I do not know if there are any other fuses or circuit breakers in the system. This is as far as I have gone to this point in time. Does anybody have any experience with this sustem or any suggestions on what I should do next?Steve
