Escape Rumba
This is a fun little boat and really easy to sail. I bought one (used) for my then seven year old granddaughter to learn to sail. She is now nine and still sails the Escape. Main sheet is mid-boom.
Here is text from old ad copy.
"Hull
· Easily transported on a car top or trailer, the hull is one piece roto-molded polyethylene with no seams to open. This creates a durable, light weight boat that can take the punishment of beach sailing, grounding, or being dragged along the shore. The hull is a distinctive bright safety yellow for easy spotting from shore.
· The wide body design makes the Rumba extremely stable. The Stable form hull design making it 3X less likely to capsize than a traditional sailboat - you'll spend more time sailing and less time swimming!
· When the wind picks up, the rounded sides offer a great platform to hike out for ultimate speed and performance. The Rumba is one of the most versatile high performance small sailboats ever designed. It combines race boat performance and the ability to carry the whole family for summer outings.
· The forward cockpit provides lots of space, and the aft cockpit features sculptured bucket seats with excellent lower back support, so you can sit, and be very comfortable in light breezes. The cockpit is also self-draining, with drink holders and mast step.
Sail Plan
· The Rumba features the SmartRig sail plan with roller reefing on the mast, usually found only in much larger boats. When you want to deploy the sail, simply pull the outhaul line and the sail unrolls. To stow the sail, pull on the furling line and the sail easily rolls up on the mast again. This also means the sail is easily adjusted to any size necessary for wind conditions. If it's really blowing, reduce sail area. If the wind is light, pull it out all the way. The sail sleeves over the two piece mast eliminating the need for halyards, and is controlled by a single mainsheet. It's no wonder the Rumba is considered one of roomiest and most user friendly boats in its class.
Specifications
· Length (ft): 12.75
· Width (ft): 5
· Mast Height (ft): 21
· Sail Size (sq ft): 82
· Hull Weight (lbs): 150 "
These photos (from sailing Texas) may help. The rig shows pretty well.
