On my E29, the shaft is 1 inch. The engine has been swapped out at some point in time, but I doubt VERY seriously that the shaft size has changed. It would be an astronomical feat for nothing. When I get down there tomorrow morning, I can get a length measurement if you like..
length is not gonna make a difference--is based on shaft size, which is able to be obtained by using a micrometer to measure the width of shaft prop uses.
my ericson 35mII uses a 1 inch shaft. my formosa 41 uses a 1 5/8 shaft. if you do not know your shaft size you cannot buy new parts.
O.K., my shaft size is 1 inch, (as I knew), but the O.D. of the bearing is 1-1/4". And it is 4 inches long. Exactly. By the way, it's a '73 model E29, I wouldn't think it would be much different than yours..
