Reading on the web I've found a couple different pieces of info that conflict. I'm mainly trying to determine when to stop equalizing the batteries.
Is it based on gravity meeting 1265, when it stops raising or just a flat time span?
Out of 4 batteries the ratings were all about 50/50 being either 1265 or 1275. The Xantrex true charge 40 has been holding them at 15.53 volts for the past hour and I'm probably just going to quit after a flat 2 hours then re-check gravity levels and top off with distilled water.
Hopefully I'm doing it right!
Jared
Jared
