		bill
Several years ago Catalina Direct came out with a fiberglass covered steel swing keel--no more corrosion worries. But when I tried to purchase they suggested that I save money and simply epoxy my old iron keel. I did so. But I did not realize that the pivot mechanism and fitting is below water. So how do you protect that without putting a zinc through the epoxy and into the keel and thus defeat the purpose of the epoxy? I have the same question for the fiberglass covered keel--if you attach a zinc to that you also have potential spaces around the screw for water to come in contact with the metal of the keel. Finally, as an aside, does anyone know if the steel in the keel affects a compass place on the outside of or through the bulkhead between cabin and cockpit?
