Epoxy on Hunter 212
David Fisher
Can anyone can tell me if you can use regular Epoxy with the Hunter 212 composite material. We want to mount an auto-tiller and use Epoxy around as a sealer around the fitting. Advice please!
Dennis
If you want to seal
If you want to seal use 3M 5200 sealer, but if you want it to bond alone use the plexas from your dealer. The epoxy or plexas won't flex, so the 3M 5200 will make a better sealer.
