I am in the process of purchasing the Envirocomfort 16K Air/heat unit and have the following question. As I do not want to add another thru hull fitting is it acceptable to draw seawater from the water intake for the engine cooling on my boat. My thought is to Tee off the through hull fitting, and add the shutoff valve, pump and strainer on the AC unit side of the Tee. Water would then be pumped to the AC unit and the normal flow of water to the engine would not be effected. Typically the engine and the AC unit would not be run at the same time. So if the engine was running, the valve to the AC unit would be shut off as well as power to the AC. Power to the AC unit when working would be either shore power or a generator.
