Eno stove
Sep 9, 2014
18
Beneteau 36cc Stockton, MO
We have a new to us 1998 Oceanis 36CC with an Eno 2 burner propane stove/oven.We tried using the stove for first time last weekend. The burners and oven will light initially then go out after a few minutes. They will not re light for a long period of time after that even if I turn the switch on the electrical panel off and back on. I replaced the regulator which did not help, made sure that the propane bottle was full and checked for kinks in the gaslines. Im going to replace the solenoid this next weekend..Any other ideas? Thanks for your help..
Beneteau 323 Annapolis MD
Don't you have the manual for trouble-shooting? You should have the maual for everything on the boat. If you don't, start looking for them NOW. Do not wait until something breaks to start searching.
Oct 6, 2010
119
Beneteau Oceanus 321 Carters Pt.
We had similar problem on our 1997 Beneteau 321 problem wes faulty solenoid
Got a replacement from local propane service centre ,this is a common 12 volt solenoid used in RVs
Sep 9, 2014
18
Thank you Ron20324 and Beneteau321 for your quick replies. We have had the boat for about four weeks.. have really enjoyed her.. I've been going through all the documentation that came with the boat but could only find a small two page installation booklet for the stove. It didn't have any trouble shooting information with it.. I'll see if I can find one online.. I hope I will have good luck changing the solenoid..Thanks again for your help..
