Tom FitzGibbon
I need to improve the ventillation in my 1979 H33 and have decided to replace 2 of the existing mushroom vents with 4" Nicro solar powered mushroom vents. The problem is that the existing vents have a 4-1/2" hole but the Nicro vents require a 4-3/4" hole. I can think of 2 ways to enlarge the existing holes, both of which have advantages and disadvantages.First option is to temporarily cover the hole with a piece of wood and recut the holes with a hole saw. The wood would allow the saw to bite into a solid surface, although making sure it is centered above the existing hole could be a challenge.The other option I can think of is to enlarge the holes using a sanding drum chucked into a portable drill. No worry about making sure the new hole is centered over the old one, but this could take awhile.Which method is better? Are there other methods that are even better? Thanks for the help.
