Practice and prioritizing/ordering
Well, heck, I'll throw my two cents in...I find that prioritizing helps me save time from trailer to water. That is, when I first get out of the car, I do stuff in order: Unload the gear/sailbags/food/aux. motor etc. first. Then loose all tie-downs/lines from the trailer/trailer mast crutch tie-down/stowed rigging (basically getting all out-of-boat stuff done first- so that I don't have to climb in and out of the boat, wasting time. Then I use a quick release pin to attach the furling jib to the mast. Next, with the topping lift line in hand, I walk the mast up and then, stepping fore of the mast with topping lift tight and very securely in hand, tighten and tie off the topping lift line on a bow cleat-- essentially using the topping lift as a forestay until I can attach the jibsail to the furler drum. Then I loose the main halyard d-shackle from its tie-down/cleat, swing it toward the bow, around the standing rigging/shrouds/spreaders and allow it to hang down, the d-shackle fully extended toward the ground. Then I climb out of the boat and walk the main halyard around to the bow. I detach the trailer winch hook from the bow eye, slacken the winch enough to hook the winch hook through the halyard d-schackle and turn the winch several cranks, bending the mast forward slightly. This creates enough tension to allow me to easily pin the jib/forestay cable to the furler drum (Again, using a quick release pin). No bloody knuckles thanks to simple mechanical advantage. Next I release the topping lift (which has been serving as a now-limp forestay) from the bow cleat. Next, back off the tension on the trailer winch and replace and tighten the winch hook back onto the bow eye (don't wanna loose the boat off the back as the trailer descends the ramp)! --and walk the halyard back to its normal position. Now proceed aft to the chainplates and tension the shrouds using Johnson shroud tighteners (see earlier posts describing these--- but once you specially dial in each levers' tightness for your rig, these babies are literally a snap). Proceed as normal with boom attachment (again, using a quick release pin), vang attachment, and mainsail "hanking"-on. Also for the mainsail, I used standard bungie cords (3) to lash the sail down to the boom and then tighten the mainsheet all the way in. This prevents the boom swinging and the sail from catching any windage when you're backing the boat in the water. As you know, the 170 will take off with the slightest windage.Attach motor, fuel up, put the plug in and back her in!Hope this helps. Once I had this process down, I went from driver's seat to captain's seat in 35 minutes!Happy sailing!Mike G. s/v Lil Sport
