Mike Collier
My 1990 Catalina 30 has a Universal Deisel (model 25). Occaisionally, when I depress the momentary start button, nothing at all happens. Push it a second, third, sometimes fourth time and she cranks right up. I recently replaced the momentary switch and it still happens. There are no obvious signs of corrosion at either the battery (plenty of power), the momentary switch or the starter. It also only seems to happen when I'm ready to motor back to the slip (that is, after the motor had already been run hard earlier in the day). I wonder if this is common, or if it is an indication that the starter is about to go bust? Or if there is some interaction between the start switch and the glow plug that I need to be aware of? Thanks in advance if anyone has resolved this problem.
