My 2GM20F went racing twice, so a service tech overhauled the cylinder head and installed new injectors. The engine raced two more times, with smoke everywhere at 4000 RPM for 25 seconds. He had missed the source of the problem, believed now to be the injector pump and/or lift pump.
Got a sample pulled of the newly changed oil that suffered the two latter incidents. An oil test by a machinery lab found 4% fuel by volume, as expected. But it also found 11 ppm of lead. My yard fears the bearings have been so damaged as to require a full overhaul, which means pulling the engine and shipping it to Mack Boring in New Jersey. Three vital questions arise.
1. Is 11 ppm lead in oil significant? I’ve read that new oil already has 4 ppm lead.
2. Why would a soft metal like lead be found on the surface of super-hard steel bearings?
3. Is the lead instead coming from the 4% volume of diesel found in the sample? Or perhaps the Cetane additive?
I attached the chemistry test for anyone who can figure it out. This is a really vexing problem, already expensive and likely to get moreso. Thanks for any advice. Capt. Bill
