Engine weight
1
- - sonora desert
I am new to sailing and am currently refurbishing an early 80's Catalina 22'. I have read that an engine 10hp or less is sufficient. How about engine weight? I have found weights from 60-110 lbs. Thanks
Bob B.
Motor HP & weight
On my 1980 C22, I use a 7.5 HP long shaft Evinrude. Weight is 59 pounds & lots of power for a C22. I made a modification for a vertical pull start. I also have an extension for the gear shifter lever. A newer 4 stroke would be great! Regards, Bob B.
Timm R
Jun 7, 2004
4
Catalina 22 Madison Wis
plenty of power
I also have a c-22 and am using an old ted williams 5 and a half that moves us along against three foot waves without a problem.I don't think you would need more than that.
BarryL
May 21, 2004
1,125
Nissan 5 HP 2 stroke
Hello, I have a 5 HP Nissan 2 stroke that works great. It weighs 40 lbs and has plenty of power. I rarely use more than 1/2 throttle, and that is enough to move the boat at 5 kts. If you are looking for a motor, make sure you get a long shaft. Even with a long shaft and the motor mount as low as it will go it is possible for the prop to cavitate in steep swells. If I were going to buy a new motor I would get a 4 stroke because they are quieter, more fuel efficient, and pollute less. Good luck, Barry
Apr 14, 2004
54
Hunter 28.5 Marinette, WI
Gear-shift extension
Bob, I have an 84' Evinrude 8HP. It's more than I need and a bit heavier than I want. If I had to replace it, I would probably struggle with the decision between the Nissan/Tohatsu four-stroke 6HP or the Mercury two-stroke 5HP. Both are very lightweight for their class. By the way, can you please post a picture of your gearshift extension? I've been thinking of doing that myself and would like to see your implementation. Thanks, Dave
Bob B.
Shifter Extension
Hello Dave: My motor is mounted on the port side so I had to reach over the motor & way down to reach the gear shifter. When motoring into my small slip at the marina, often singlehanded, I am crouched up on the seat so that I can see forward. Reaching for the tiller was OK but needed longer arms to reach the gear shifter & usually this is at a critical time. The extension is a piece of 1/8" X 1-1/4" flat bar. I narrowed & curved the bottom end for a good fit into the depression in the existing lever so the extension cannot pivot on the new bolt. I could post a picture of the bottom end. Put a bit of cord on the handle end just for looks. Regards, Bob B.
Bob B.
Shifter Extension Picture
Dave: I posted a picture of my shifter extension on my previous reply but it has gone somewhere?? Here is another try. Bob B.
May 20, 2004
10
Catalina 22 Oshkosh, WI
Thanks Bob...
Thanks for the pic Bob! My motor looks very similar to yours. I just may "steal" your design and make one for myself. I have the same problem having to reach for the shift lever when manuevering through the marina. Just yesterday there was a lot of activity in the marina and I had to start and stop a number of times.
