Mike Somers
Hello all. I have a 2006 Hunter 33 with 161 hours on engine. I just changed from the 3 blade fixed prop to a 2 blade gori, 16.5 x 13 x 1, and have noticed significant vibration now at different rpms. At the dock, reving up to max rpm, I get no vibration. I had a Yanmar specialist check out the mounts, shaft, alignment, and all looks good. I also talked to the dealer I bought the prop from, and they indicated that I would feel more vibration from a 2 blade than a 3 blade.Also, at 2000 rpm, in calm weather, the boat moves close to 6 knots, so I don't believe I am underpowered. Under sail, I am getting 1/2 knot to a full knot increase in speed over the 3 blade, so obviously I am happy about that.What else can I look for, or is this normal?Thanks,Mike
