It depends on your meaning of "reasonable". There will be a slight vibration, but if there is a lot of movement, then the engine mounts mat be loose or defective. It could be where the engine bolts to the "mounts" or where the "mounts" are lag bolted into the stringer under the fiberglass. If it's the lag bolts, they may have chewed uo some of the wood in the stringer. If thats the case, you can remove the lag bolts and put in some "Get Rot" epoxy with some oak slivers mixed in with it. Cut some slim oak strips and put 3 or 4 of them into the hole. Then add the "Get Rot" mix into the hole and insert the lag bolt (apter spraying it with "Pam" or some mold release), and bolt it down snug. The oak strips give the lag bolts something to bite into. Give the epoxy time to fully cure, then run the engine. It should be quite secure. If, of course, its the joint between the engne and the mount, you can just tighten it or replace the engine mounts.
I had the severe vibration problem and did the first fix to the lag bolts. Some 4 or 5 years later it is still tight. In my case it was only one lag bolt (Fwd - Port lag bolt).
Hope this is somewhat helpful.
Dick, S/V Puffin 1990 H-33.5
