engine trouble
34
hunter 19 slaughter beach
I have a Hunter 19 with a 1995 8 hp honda
this weekend it seemed like the prop was slipping at times and delivering no or little thrust then went back to normal
Any one else have this happen
I am concerned about using it but since it is the end of the season what should i do
Clark
Jun 30, 2004
886
Hunter 280 Lake Guntersville, AL
Could be cavitation or possibly your prop hub/shear pin. Fixing the first is easy and cheap and the second one shouldn't be very expensive.
RichB
Oct 8, 2006
87
Hunter 23 Winter Park, Fl. h23
To expand slightly on Clark's reply:
If you don't have thru hub exhaust then you should have a shear pin. ...... simply replace it.
If it happens to be a thru prop/hub exhaust then you will have to take the prop to the shop for a new rubber insert w/ spline. It takes a machine to squeeze the new rubber into the hole. about $60.00 should do it.
34
thanks
I did this the pin looks ok Should i still replace it and try it again?
