Engine, transmission alignment
sfgary
123
Challenger sloop Alameda
I lost reverse about 5 weeks ago and have since had the transmission rebuilt. I am replacing the motor mounts while I have the engine jacked up. I want to make sure the transmission shaft lines up perfectly the the prop shaft as the cutless bearing is fairly new and don't want to risk a vibration from misalignment. I don't know how to do this. Any help would be greatly appreciated.
Thanks in advance
Gary
Dec 2, 1999
15,184
Gary:
I cannot give you any advise on how to do this procedure, but if you want to hire someone to assist you I can suggest someone.
Bill Ingle of Bill's Marine 510/708-9391. Tell him Steve from Hidden Harbor told you to call.
Ross
Jun 15, 2004
14,693
I will be glad to do it for free if you cover my transportation, meals and housing. ;)
Hunter 34 Alameda CA
Hi Gary,
Don't make me come and help you! Send me a message through the site and we can exchange info. I'm up at the boat now and will be around for a while tomorrow (Sunday).
Allan
Sep 29, 2008
162
Morgan Out Island 33 Pompano Beach
I have an old article from Good Old boat that explains the how to of alignment. Email me your address and I'll copy and mail to you. Also, if you have that much torn apart, you may want to consider changing out the damper plate. Bob Tigar bjtigar1@netzero.net
sfgary
123
Thanks guys, you have given me a lot of great info.
Gary
arf145
Nov 4, 2010
495
Beneteau 331 Deale, MD
Gary, basically the process is to use a feeler guage between the coupling on your shaft and the flange coming off the transmission. These are supposed to meet with a gap of no more than--generally--something like 6/1000 of an inch at all points. You accomplish these minute adjustments by horsing the mounts with that big engine on them--which can be a pain in the butt.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
I spent 10 weeks apprenticing for a marine mechanic, during which we did several alignments. His spec was 4/1000 (4 mils) or better. Otherwise it was as arf145 has described. I believe we would work as follows:
- before starting, all other shaft issues should have been checked and dealt with: cutless bearing is good, no alignment problems with strut, shaft isn't bent, coupling is solidly mounted to prop shaft and bolts secured with wire or loctite.
- with the bolts securing the mounts to the boat rails slightly loose, we shift the engine side-to-side to roughly line up horizontally
- we quickly adjust the mount lower bolts up/down to roughly set the vertical alignment
- at this point we can now pull on the shaft to mate the couplers. Usually the misalignment gap at this point is visible and we repeat the horizontal then vertical adjustments to improve that.
- now comes the 4 mil feeler gauge. We mate the coupler then feel around between the faces. If the gauge can be inserted freely at any point, the engine needs to be shifted slightly. Again we try for horizontal alignment first (worst gap is at top or bottom) then we can snug up the mount bolts to secure the mounts to the rails
- finally we tweak the lower bolts on the mounts to shift the engine up or down
- when the coupling faces are mated and we cannot freely insert the 4 mil feeler at any point around the coupling... the alignment is good. At this point we tighten the mounting bolts fully and spin down the upper bolts, tighten, and check the alignment one more time. If that's good, then we can bolt the coupling halves together. Done.
I am surprised that we don't have a higher-tech solution to alignment issues than this 19th century process, but it is what it is...
I haven't been impressed with the quality of the usual engine-mounts, and how they fail in 3 to 5 seasons, or tear after a rope fouls the prop. If anyone knows of a longer-life aftermarket mount, I'd love to hear about it.
sfgary
123
Thanks Kenn, Thats great info. All the issues in the first paragraph have been addressed. I am waiting for my new dampner plate so I can start the bell housing and transmission installation, I don't have a strut as its a full keel boat. Thanks again
Gary
