Butch
Cure one thing and it is always something else. After discovering there was no flow thru the mixing elbow (overheat problem), I replaced same. Sounds easy. Not something you want to try every day. After getting some decent water flow, I discovered that the temp never seemed to go above 140 F. That seemed awful low for an engine, so I put in a new thermostat. The old one was stuck open. It still runs in the 140 F range. Can anyone comment/ help here? Is that the correct operating temp for a YSM12R?
