Engine Temp Gauge
Oct 30, 2019
574
Our temperature gauge for our MD-6A has not been working or some time. Does anyone know where I can get a new one and how to replace it...or even if it is worth replacing?
Thanks,
Jack
Bella - V2620
Oct 19, 2019
921
Albin Vega 27 Limerick
For what it is worth, following advice on this forum a few years ago, I removed the sender from the engine block, immersed it in boiling fresh water for a few minutes and then reconnected.
Since then it has worked fine.
John V1447 Breakaway
John Kinsella
Mathematics and Statistics Dept
University of Limerick
Phone 0035361202148
Web jkcray.maths.ul.ie
May 30, 2006
1,075
Temperature is very important to know......
On my MD6A, it used to get hot all the time. What happens is temp would rise and rise and rise, and when it gets to boiling, 100C, it stops going up. Of course. While the boiling water in the tubes of the engine boil off even more minerals onto the sides of the engine innards.
Not sure what else bad can happen if unchecked but Im sure its not a good thing.
Also, I am planning (way down the list right now) a new gauge package and started on this project but put it asside. I bought a full gauge package from Faria. The small ones like temp were like $25 each.
Many other brands out there.
If you find ur engine overheating, there are also things to be done further.
groundhog
Nov 8, 2001
1,818
Hi All
When I bought my first vega with an MD6A it had a working temp gauge, I used to spend every trip (when the engine was on) looking at the temp gauge, I was paranoid about it. The best thing that happened was the gauge ceasing to work! Every trip after that occurance was bliss as I never looked at teh gauge, I used my other senses. Listen to the engine, smell if it gets over-hot!
I know overheating an engine is a massive "no-no" but it improved my appreciation of using my Vega.
All said my Beta has a temp gauge but I have learnt not to rely just on a needle behind a small piece of glass. Trust your senses.
Cheers
Steve Birch
Oct 19, 2019
921
Agree with Steve - the smell of an overheating engine is memorable!
Hot paint..
John Kinsella
Phone 0035361202148
Oct 30, 2019
574
Well, for what its worth, I doubt I motor for 4-5 hours in a season (usually 4-5 months). At least two of those are going to/from the yard where we haul out. I've never had an issue with overheating (that I am aware of). But, if I can wash it in water to get it to work, what the heck.
Thanks for all the great advice!
Jack
Oct 30, 2019
1,459
I gotta say that the engineers put those those gauges and alarms there for a
reason - a failed gauge or failed alarm can lead to cascading problems and a
blown engine. Shouldn't let that stuff slide, IMO.
Nicholas H. Walsh P.A.
111 Commercial St.
Portland ME 04101
207/772-2191
Fax 207/774-3940
This email is from a law firm and may contain information
that is privileged or confidential. If you suspect
you were not intended to receive this email,
please delete it and contact us.
Feb 13, 2010
528
I also glance back at my exhaust on a regular basis a small amount of
steam in warm weather is likely all right a lot more in cold weather but
if there is a massive amount of steam you can bet there is something not
right. If the water in the engine is boiling the engine is not likely
damaged but when it stops look out you are likely over heating the metal
to the point of damage. AS every one else said your ears will tell you.
When the heat gets damagingly high their is usually some rough running.
By then you may have damage. The good news is with the engines
running about 140 degrees the temperature has to rise a lot. I have a
meat thermometer and a small hole drilled in the front of the cockpit.
The previous owner did this and it works pretty well. If I am feeling
concerned I shove my thermometer in touching the engine. The out side is
usually running about 120 to 130 degrees this doesn't tell me much
except that something is abnormal. I have only used if it a few times
in the winter when I get paranoid about the amount of steam coming out
the exhaust pipe:) I don't have a thermostat at the present time so
my engine is running a little cool but would be way too cool in colder
weather.. I have one to put in that I bought used. I checked it in a
pot of water heated to 150 and it is open at that temperature so I will
install it when I go to the boat. Doug
Oct 30, 2019
574
Am I the only one who finds the thought of Doug sticking a meat thermometer through a hole in the front of the cockpit to be hilarious! No disrespect, Doug. It just made me chuckle.
Jack
Feb 13, 2010
528
Don't feel by your lonesome I laughed to when he told me. He is a Navy
chief and said he keeps one in his pocket for a quick check on bearing
temperatures board his ship. Hey it's close enough to tell me I need to
get a real thermometer he said kind of sheepishly.:) Doug
Feb 13, 2010
528
Yes that is a pretty nice tool and has the advantage of being handy for
checking autos your home heat and aircondition as well. OF course if
you are anything like me it will always be someplace else when I need it
on the boat. Thats not the fault of the tool though. Doug
