Hello,
I’m trying to purchase a Hunter 28.5 with a Yanmar 2GM20F and have had an engine survey conducted and it came back with a lot of problems. The boat is a saltwater boat and has been on the hard for 3 years. The owner swears that the motor runs fine but for the price he’s selling it for he says he is unwilling to put the boat in the water for a sea trial. I don’t get the impression that the owner is dishonest but I think he is not very familiar with boating or sailing and he hardly used the boat. I decided to have an engine survey done and a visual inspection and compression check of the engine was completed (for 500) but the engine could not be run due to a blockage in the corroded exhaust riser. The impeller needs to be replaced, the belts are worn, the forward engine mounts are loose and the surveyor recommends realignment?? The wrong type of antifreeze was used in an environment that gets below the protective value of the antifreeze. The engine oil is low and really dirty and the propeller shaft/ transmission coupling is corroded and leaking at the packing. All of the hoses need replacement.
The boat is a project boat I can get it for 6k and I’m not afraid of the fiberglass and gel coat work but I have little to no experience with diesel engines or inboard motors at all for that matter(although I’m good at restoring outboards).
I would appreciate anyone’s advice on some of these repairs if you’ve done them yourself or had them done.
Thanks
JDB
Thanks
JDB
