E
Ernie tetrault
Okay, I checked and I don't have those bleed screws that were mentioned. I did try to bleed that line between the filter and the pressure pump. There were some bubbles at first, then clean fuel. I started it again, and once more it died after five minutes! Help!!!Also, when I bled the system earlier, I hit the high pressure side too. Should the fuel be "gushing" out of the high pressure pump, or is a slow flow okay? Please tell me I don't have to replace the high pressure pump!!What is that procedure you mentioned to Alan?Thanks,Ernie
