engine sizes
Brad Truby
What is the max size outboard that i can put on my boat i have a 25.5 with a 8 hrp engine on it and was woundering what i can go up to . Were i live i need something with a little more power because it can get pretty hairy at times and need to get inland a little faster . Just woundering . Brad
mike43067
Hull Speed
Due to the principle of hull speed I doubt that a larger motor would propell you any faster. It might help power you against choppy seas or current, but no faster.
Dick Vance
I Coulda Had A V-8!
Brad, The limiting factor is the weight your engine bracket will safely support. I have an Evinrude 6 on mine (its the same engine as the 8 with different carbueration) and it will push the boat to hull speed in flat water. In a blow or rough water the 6 is definitely underpowered. My choice for upgrade would be the Honda 9.9 four stroke. One of my friends put one on an older Hunter 25 and it had loads of extra power. The extra 37 lbs over the 6 or 8 was no problem. The Honda 15 is the same weight as the 9.9. (see specs at: http://www.honda-marine.com/ ) My previous boat was a 2200 lb. 20 footer and it had a 15hp on it! Talk about reserve horses!! Dick Vance H-25.5 "Honey Bear"
Dave Condon
Motor size
Although most sailboats do not specify the maximum motor, what I would recommend is based on experience. First the Tohatsu/Nissan 8 & 9.8 are basically the same block witht the 9.8 given more horsepower. This would be true with the 9.9 and 15 both being the same block but the 15 having more power of course. There are many theories but based on experience, the maximum horsepower would be a 9.9 whether it is 2 or 4 cycle for your boat. Most folks should remember that sailboats are displacement hulls that sit in the water pushing it aside whereas power boats are planning hulls that require for the most part the excess power to get the boat on top of the water in order to move. If you have for example a 15 horsepower on the back of the 25.5, you will see under full power the bow raising up thus plowing through the water and slowing you down. When you reduce power, the bow will lower and if you had a knot meter, it would prove my point. Simply put, 9.9 for your boat would be ideal. Happy sailing
