Mike Freeman
Engine size for MacGregor 26X.I am about to order a 26X for use here in UK and France and I need to make a decision on the size of engine. I am a sailor and not interested in towing water skiers. If I need to move quickly it is because bad weather is coming. In coastal waters this means wind of force 4 to 5 and short steep waves about 2 to 3 feet high. I’m told you can’t use the full power of a 50hp engine in these conditions. A 30hp, say would save on weight, initial cost and fuel costs. A 50hp Yamaha needs about 5000 revs to give full power. Can owners tell me how often they use these revs and what revs would be sensible in the sea conditions above? I’ve checked the forum archives and got some info but nothing much on the sea state factor.Then there is the choice of prop size. It all gets a bit complicated and this is maybe why most owners just fit the biggest engines and use lower revs. A UK owner tells me that only using low revs has given him some maintenance problems. Any advice from US owners, particularly coastal and Great Lakes sailors, would be very welcome
