Get a Long Shaft 6 HP
Lee: A long shaft motor will solve this problem.  Did you check with the previous owner to see if he or she used a long shaft engine on your boat before?  I would bet that your motor mount is in the right place for a long shaft motor.  Relative to motor horsepower.  I was just given a 5 HP Honda motor to use while my 6 HP is in the shop.  With the 5 HP, I can only get the boat to go 5 knots/hr.  With my 6 HP, it would go 6, which is near the theoretical hull speed of the boat.  I can tell you that 1 knot/hr. makes a huge difference if you are going 40 miles on your boat one way, as we did last weekend.  The 4-stroke Honda used very little fuel, didn't smoke at all, had great starting out and great reverse power, but it's not the right engine for my C-22.  I need a 6 HP.  I would check into the Nissan motors.  They are much lighter than the Hondas.  The Honda also had a tendency to rip the stater handle right out of your hand.  It happened to me once and to my 16 year old son once, and it wasn't a pleasant experience.  Both of us could feel it in our arms the next day.  (I guess if we had the motor for any length of time we would figure out what caused this, or get used to it).  I would only buy a 4-stroke engine for my next motor, although I am currently having my Johnson, 6 HP, 2-stroke repaired at this time.  We use our boat over what I consider long distances for a C-22, and with a 2-stroke motor, it just takes too much fuel in weight and room.  With a 4-stroke motor, 6 gallons takes the boat a long way.    I hope my thoughts help you.   Aldo
