Is a 25 inch shaft better than a 20 inch shaft on the engine for a 222 O'Day sailboat? We are looking to buy a 6 hp 4 stroke long shaft engine.
Thanks,
Gene
Thanks,
Gene
This is the right answer. We had a Catalina 22, 1981 boat bought in 1983. They started making them almost a decade if not more before then and EVRYONE even back then said get the long shaft or you'll regret it They were right. Still are.When you really need it to make way against headwinds and waves on the nose the propeller coming out of the water will limit your capability and you are helpless against it.
Been there done that.
