Engine / Shaft Alignment
Rich M
Nov 5, 2007
74
Hunter 28.5 Annapolis, MD
I have an 85 28.5 and over the past few weeks the yard finnally replaced the Cutlass Bearing and the prop. At the end of last season the engine was pulled and the transmision replaced. i have also replaced the packing gland with a proper metal unit. Now the big question is how do I make certain that the shaft and trans are properly lined up. I went through the Yanmar Engine manual I have and could not find any suggestions. I'm sure someone out there has the proper procedure and I obviously need the help. Thanks In Advance.
Hunter 34 Seabeck WA
It's a touchy-feely thing,
as in 'feeler gauges'. I suggest a search on this site. But here's the short version. Alignment is dictated by the strut. It aims the shaft at the engine. The shaft is also positioned by the shaftlog. The log isn't suppose to change the direction the shaft points to, but just supports it. If you understand the concept then imagine the coupling on the shaft, pulled away from the transmission. The face of two halves of the coupling have to move together and join with bolts. Think of a space capsule joining another spaceship. Clunk, contact, capture! What you need to do, just before capture, is use a thin feeler gauge between the two halves of the coupling. Shoot for 0° error measuring at four points, 90° from each other. Do not try to move the shaft. It's angle is fixed. You'll notice that it can droop when not connected to the engine. That's OK. Just bring it forward to the engine coupling and try to contact it. Then push them together and measure. Another way to measure is to use pieces of a torn matchbook cover. Insert the pieces at the four 90° locations. Pull each from being captured and try for an even pull. Close is good. Now this all assumes that you understand how to move the engine mounts so as to position the engine to be pointing with the shaft. Think of lining-up a gun sight. All movement is done at the mounts. Try to get it as close as possible before launching. After you splash, wait a few days so the hull settles and do it again. And you get to pretend that you're flying a space ship. And yes, on our boat with the dog's waterbowl on the cockpit floor and motoring at hull speed, the water is flat and calm.
Aug 9, 2005
772
Hunter 28.5 Palm Coast, FL
Without getting highly technical....
and to tell if the alignment is close to being correct. Put the transmission in neutral and spin the prop shaft, if it turns easily the alignment is roughly in line. If it isn't the prop shaft will turn tightly as if it's binding. This works for when the boat is hauled. For in the water there should be no knocking of the prop shaft in the stern tube. If there is, try using a pry bar and repositioning the engine while running up and down and side to side to stop any knocking. Just be very careful as you do this. Because fiberglass hulls change shape when on the hard and when in the water, a proper alignment as mentioned by Fred can only be done when the boat has been in the water after a few days. Also a two cylinder diesel that's in the 28.5 will never be as smooth as the three or four cylinder in Fred's larger Hunter. Good luck.
